Mobile Audio / Electronics
Subject Topic: Speaker Wires Post ReplyPost New Topic
PaperBoy
U.S. - Kentucky
Posted: Oct 22 2013 at 10:40am | IP Logged Quote PaperBoy
I upgraded the door speakers in my 09 Frontier King Cab.   While researching this upgrade, I found a lot of discrepancies regarding the “Wire Colors” for each of the four speakers.   Unfortunately, no one provides an adapter plug for the 05-13 Frontier. You will have to cut the plugs off and wire in the new speakers.    Nissan doesn’t show a polarity mark on the factory speakers.    Here’s a little trick you can do to determine the Positive (+) speaker wire:    Remove the factory speaker, and hook a battery (1.5 V AA, or C, D) whatever you got handy   across the speaker terminals.   When the Pos + Batt post is connected to the Pos + speaker terminal, the speaker cone will move “Outward”.   If you hook it up the other way, the cone will move “Inward”.
1998 Frontier XE
2009 Frontier. SE
Back to Top View PaperBoy's Profile Search for other posts by PaperBoy
Posted: Oct 22 2013 at 10:03pm | IP Logged Quote lakota
Great... I didn't know that...Thanks!
Have a good one.. Don S..
