Pacer6 Groupie
Online Status: Offline Posts: 76
Posted: Mar 06 2020 at 11:49pm | IP Logged
Cannot seem to locate one of these, any help?
Rubble Moderator Group
Posted: Mar 07 2020 at 12:06am | IP Logged
help?
Pacer,
Go to: https://www.nissanpartsdeal.com/
Get the Part # and Price, then go to EBay and/or Amazon
and punch in the Part Name and # to see if someone has
one listed.
If no go then use your Search Engine and punch in the
name and part # to see if anything will pop up.
If still no go, then search Nissan Truck Salvage Yard
with your Search engine.
Out of all that I'm thinking something will pop up and
hopefully won't cost much.
I know what you mean, cause I have a KC with a Full
Size Rail To Rail UWS Aluminum Tool Box, which hold's a
pretty good bit and that thing Filled up Fast.
If you could find out the previous Owner's Name/Phone
#, He/She may still have it stuffed up above in the
Garage. They might just give it to you.
Regards,
__________________ Barney
Pacer6 Groupie
Posted: Mar 07 2020 at 7:51pm | IP Logged
I called Nissan, they look for the item. It is not available unless it came with the vehicle. Our other is used out of another vehicle or at the junk yard.
Crazy ain't?
Posted: Mar 10 2020 at 8:16am | IP Logged
at the junk yard. Crazy ain't?
Pacer,
If the exposed metal for the plastic lock down bolt's
are visible, then a prior year '05-'16 is a probable
fit.
Nissan is fixing to come out with a New Body Design for
the Frontier, and are probly trying to save money by
depleting as many parts as they can without buying more
inventory that will be left over and need Storage
space.
They also eliminated the Hand Grab Hold for the A
Pillar on the Driver's side too since my '13 was made.
If you can find out the part # for the Storage Bin for
under rear seat for an older model between '05-'16
there is a good chance that it will fit IMO.
This may be it and there is 2 storage bins:
https://www.nissanpartsdeal.com/parts/nissan-box-rr-
side-rh~76982-ea202.html?
Make=Nissan&Model=Frontier&Year=2013&Submodel=&Filter=
()&Location=body_side_rear/rear_back_panel_trimming,,76
982U
Weather Tech and Husky offer an under rear seat storage
bin and may have one for the CC under rear seat.
I'm thinking that you should be able to find one,, but
it will take some time and effort on Your Part.
Storage and Full Length Bed is why I held out for a
King Cab. One of the 1st thing's that I did was get a
UWS Top of RAil to Rail Toolbox, so I could keep the
dirty thing's that I need in it and Locked. Mine is a
Full Size,, but they have 1/2 size same kind for the
Crew Cab's, but that really Reduce's the Cargo Area in
the CC Bed.
Good Luck,
Posted: Mar 10 2020 at 11:12pm | IP Logged
Pacer,
Looks like Weathertech has one for your 2017 Frontier
Crew Cab:
https://www.weathertech.com/nissan/2017/frontier/under-
seat-storage-system/
On the Nissan OE: Look's like they have it in 3
different Color's ~ Charcoal, Steel, and Sand/Beige.
Look's like for the CC, it is in 2 Piece's ie The Right
Side Passenger look's like the larger Bin and the Left
Side Driver is Smaller.
If you could find one at a Salvage Yard where a
Frontier has been totaled, that might be your best bet
as for Price, but the Weather Tech actually look's more
functional IMO.
I saw a 1/2 Size Aluminum Rail to rail at a Gas Station
and that thing might just be cost effective and hold
more,, but you'll probly lose close to a Foot of Cargo
Space. If you decide to go with the Aluminum Tool
Box,, you could alway's get you a Utility Trailer;
Something like a 5' X 10', then when you needed to haul
anything of any size, just hook up the utility Trailer.
I have a 5' X 10' Utility Trailer Single Axle no
Brake's that I use when something is too heavy or Too
Bulky, or Might damage the Bed, Like Equipment for my
Tractor, or if I needed to get something like a Matress
Set or Disk with Blade's that would cut the Bedliner, I
just hook up the utility Trailer. One Very Good
Feature about My utility Trailer is that it came with a
Ramp that make's for easy loading of the Lawnmore,
Motorbike, Tractor, etc.
Just giveing you some idea's that you might not have
thought about. I see more and more people useing a
utility trailer to haul what they need moved.
Regards,
Pacer6 Groupie
Posted: Mar 11 2020 at 7:20pm | IP Logged
Thanks Barney. I had emailed Weathertech, they said they would have one in 6-8 weeks. It was still in design.
They do seem to be very proud of a piece of plastic.
Thanks again.
Posted: Mar 12 2020 at 7:34pm | IP Logged
plastic. Thanks again.
Pacer,
Yes Weathertech is pricy.
Another option is to build one, if you are somewhat
handy with woodworking, Plexiglass, or even FiberGlass.
But probly best pricewise is to find one out of the
Salvage Yard. I think the OE are in 2 Piece's one for
Right Side and Small one for the Left side.
Regards,
Pacer6 Groupie
Posted: Mar 15 2020 at 8:48pm | IP Logged
I think I am going to junk yards first and see if any are available. They may be in poor shape, but don't know until I try.
