Subject Topic: 2004 frontier weight? Post ReplyPost New Topic
niranfleury
Posted: Jun 09 2006 at 1:57pm | IP Logged Quote niranfleury
I have a quick question. I purchased a 2004 Nissan XE crew cab about a month ago. It has a v6 which I think puts out 180 hp. Now it does not seem as quick as I would like it to be. Is that due to the weight of the truck? Compared to other trucks does it weigh alot more? Let me know.
Thanks.
KimGary
Back to Top View niranfleury's Profile Search for other posts by niranfleury
hintonl
Posted: Jun 10 2006 at 12:18am | IP Logged Quote hintonl
If you look on the inside of the driver side door there should be a sticker with all the information you need as far a GVW.
2K Crew Cab Converted to 4X4
niranfleury
Posted: Jun 12 2006 at 9:52am | IP Logged Quote niranfleury
I just wanted to know why it doesn't seem quick. I'm thinking it because of the weight.
KimGary
vuch
Posted: Jun 12 2006 at 11:56am | IP Logged Quote vuch
The XE has a 4-cylinder.
Back to Top View vuch's Profile Search for other posts by vuch
niranfleury
Posted: Jun 12 2006 at 3:13pm | IP Logged Quote niranfleury
Well... My Nissan is a crew cab so it has the V-6
KimGary
vuch
Posted: Jun 12 2006 at 8:59pm | IP Logged Quote vuch
Ooops...my bad. I thought all xe's had the 4. I think the crew cabs weigh about 4400 lbs.
vuch
Posted: Jun 12 2006 at 9:11pm | IP Logged Quote vuch
Here is a stat sheet for the 2005 Frontier.
http://www.courtesyparts.com/frontier/D40_specs.html
vuch
niranfleury
Posted: Jun 13 2006 at 12:33pm | IP Logged Quote niranfleury
That's alot of weight!!!
KimGary
smokeydadog
Posted: Jun 14 2006 at 9:16am | IP Logged Quote smokeydadog
Gross vehicle weight, the number listed on the inside of your door, is not the same as curb weight. GVW is the weight of the vehicle plus passengers, cargo, etc. The curb weight of an 04 XE is around 3800 pounds. I got that info here: http://www.autosite.com/content/research/vir/index.cfm/vehic le_number_int/1014603/Action/StandardFeatures
That's actually not too bad. I have an 05 king cab 4x4 with a V6 and I weighed at the local landfill. With me (170 lbs) and half a tank of gas it came out to 4500 pounds. Tubby! :)
Back to Top View smokeydadog's Profile Search for other posts by smokeydadog
