Posted: Apr 01 2011 at 3:52pm | IP Logged
Heat kills the fluid in the tranny... the bad fluid kills trannies... Install external cooler whether you tow or not. The cooler can be installed under the bed away from the muffler. There it will disapate heat very well even without a blower. Run the line to the external cooler then to the Radiator to heat the fluid in the winter if you are 'up north".... Why add the tranny heat to the radiator?
Keep your mule good and cool! Don S..
