Subject Topic: Antenna Post ReplyPost New Topic
Am4wag
U.S. - Maryland
Posted: Jan 30 2011 at 5:43am | IP Logged Quote Am4wag
Was wondering if a coventional/universal/generic antenna cable can be spliced to an OEM antenna cable.
Back to Top View Am4wag's Profile Search for other posts by Am4wag
Posted: Jan 31 2011 at 6:51pm | IP Logged Quote frontierguy
As in an extra ant. or a replacement ant.?
Am4wag
U.S. - Maryland
Posted: Jan 31 2011 at 10:00pm | IP Logged Quote Am4wag
Don't have one right now,and the hole in the cowl behind hood is present.Found a couple in the junkyard on Exterras.But their cable "dissapears" up behind the heater/ducting under the glove box-rendering removing immpossible w/o removing majority of under/in dash stuff first.Thinking I'm going to be useing an aftermarket stereo,which take a generic type antenna cable connection,why could'nt I just cut the cable from an OEM base,and solder splice a generic cable allowing me to route it to the stereo and eliminating the need for an antenna adapter as well.
Posted: Feb 01 2011 at 7:22pm | IP Logged Quote frontierguy
Removing the glove box should gain you enough access to
remove the ant and cable, may need to remove radio if still
in the vehicle. Splicing an ant cable, I wouldn't want to
do it.
Am4wag
U.S. - Maryland
Posted: Feb 03 2011 at 7:08pm | IP Logged Quote Am4wag
I was going after an assy. in an Exterra at the junkyard-already had the glovebox gone.But under that is the heat/air con. ducting and more stuff-more than I really want to be ripping out.If the stock antenna cable is basically a 2 wire deal,then I can solder the leads together (done it a million times on c/b,vhf's in boats).
