Am4wag Groupie
Posted: Jan 04 2011 at 9:55pm | IP Logged
Trying to find one @ junkyard.No dice.But did see a couple in Pathfinders/Xterras.They're mounted on top of the driver's side fenderwell.Mine's mounted on driver's side down below the headlight.I have the room,but don't know if a bottle out of a PF or Xterre will work in my 98' Frontier.Any body done this?
Posted: Jan 05 2011 at 6:37pm | IP Logged
If you can make it fit go for it.
Am4wag Groupie
Posted: Jan 29 2011 at 7:46pm | IP Logged
Just to pass this along-I scored one from an older Pathfinder that mounts on top of driver's side fenderwell.Has 2 pumps-I'm assuming the extra pump was for the rear window hatch.Anyhow,my Frontier accamodates the metal bracket bolts but not the tab at the front portion.But with the metal bracket bolted down,it sits firm and does'nt shake.
