Subject Topic: poor gas milege Post ReplyPost New Topic
Bryon B
Posted: Jan 10 2010 at 8:59am | IP Logged Quote Bryon B
own an 07 Frontier SE V6 crew cab about 6 months...30k showing on the speedo...16 mpg ? sheesh...I am easy on the pedal (no rabbit starts) and use the cruise as much as possible...other than a dealer tune up (major bucks) how do I improve the gas mileage? ... or don't I ? and will money spent at the dealer even help ? any ideas ?
Bryon in PA
Back to Top View Bryon B's Profile Search for other posts by Bryon B
dannyg
Posted: Jan 10 2010 at 1:49pm | IP Logged Quote dannyg
Danny here is that 16 city or interstate driving. I pull 15-17 in city and 21-22 hiway. my truck is stock 4.0 auto trans
06 frontier 4.0 auto
Posted: Jan 10 2010 at 6:51pm | IP Logged Quote frontierguy
Middle of winter, type of driving, 2-4 WD, man - auto, snow tires, tires set @ 35#, all these are factors in mileage. Are you checking after using a full tank or 1/2 tank? I just filled my truck after only using 1/2 tank and got 16mpg-warming up before leaving work, been very cold, etc. Usually get 20 or better. Right foot is very critical on gas mileage.< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
davidjbrady
Posted: Jan 10 2010 at 10:24pm | IP Logged Quote davidjbrady
I never get less than 18 MPG, ( Even when I drove in 4X4 over Donner Summit (Over 8000 feet) in a snow storm about 40 miles long, doing under 25mpg, I still got 21 MPG.   I usually average over 19.5 and have gotten as high at 24.6.
When I drive, I almost never let the RPM go over 2500, there is no need to, the engine has super torque at lower RPMs and can handle most hills, also I am not taking hills at 70 MPH either. It usually shifts into OD by the time I hit 40 MPH. I find the best MPG is between 65-70.
08 Frontier CC, 4X4, LWB
Bryon B
Posted: Jan 11 2010 at 8:35am | IP Logged Quote Bryon B
wow...mine is overall...approx 75/25...75 being city...4.0 V6 w/ auto ... 4 wheel drive...my mileage is just rotten
Bryon in PA
Bryon B
Posted: Jan 11 2010 at 8:42am | IP Logged Quote Bryon B
you guys are getting much better mileage than me...I am easy on the pedal...very conservative driver...been very cold here, as well...I always let my truck warm up prior to leaving the house...I have checked mileage several ways...full tank or half tank...doesn't matter..always around 16-17...i am very disappointed...but then I thought...well, it's a truck and it's 4wd...yadda yadda...I think I answered my own question...maybe a tuneup is in order...bought this truck used...has 30,000 showing on the speedo and I wonder if this truck was abused a little prior to me buying? sounds to me like everyone else is getting much better mileage than me ... regardless of conditions
Bryon in PA
davidjbrady
Posted: Jan 11 2010 at 12:20pm | IP Logged Quote davidjbrady
I would start with the air filter, how does that look?
30K way too soon for a tune up.
Are the tires the original size?
Bryon B
Posted: Jan 11 2010 at 1:24pm | IP Logged Quote Bryon B
tires are original tires OEM 265/70R16 manufacturer recommended size...now the air filter, that's something I did not even think of...so many other things going on...it slipped my mind...although it was at the Nissan dealer after I purchased the triuck (approx 26,000 miles at that time) for a once over and they said everything looked good...I need to look at the air filter and then see where I'm at ... Thanks for responding so quickly...greatly appreciated...Bryon
Bryon in PA
Bryon B
Posted: Jan 11 2010 at 1:29pm | IP Logged Quote Bryon B
just checked air filter...looks new ! very white ... minute small area of grey near bottom...nothing I would change it for...It looks new...or just about
Bryon in PA
Posted: Jan 11 2010 at 8:32pm | IP Logged Quote frontierguy
Is it a GENUINE NISSAN oil impregnated air filter? It will say Nissan on it and the part # is 16546-7S000. Plugs are good till 105K. Clean and tighten all the engine grounds, may want to check with your dealer on the 2 degree timing advance. Remember, it's cold out, I'm sure it will improve come spring time.< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
Page of 2 Next >>
