05nismoking Newbie
Posted: Apr 13 2009 at 4:39pm | IP Logged
hey i have an 05 nismo kc 4wd with a 2" coil spacer and a 1.5" block in the rear, i want to run 285/75/16 bfg AT, anyone know how much trimming will be involved with installing these if any? thanks in advance
dannyg Senior Member
Posted: Apr 14 2009 at 9:27am | IP Logged
From I`ve read 0- taking off your front plasic in front of your tires. what you did is next for mine how hard was the front coil spacers and bump stops. A friend off mine did the same thing 2in up front were the inner plastic fender is by your front bumber cut about 2 inchs in a half moon shape. now he is running STT Cooper wich is a truch 33in tire. go to bfgs website you might not need to trim that much
06 frontier 4.0 auto
