Subject Topic: Trying to buy a Frontier Post ReplyPost New Topic
RedFive
U.S. - Arizona
Posted: Jul 24 2008 at 3:21pm | IP Logged Quote RedFive
Hey guys,
I'm a college student and I need to replace my old Jeep. I've kept her going long enough and it's time. I think I know exactly what I want, but I've run into problems finding it.
What I'm looking for is a 2000-2002ish super charged crew cab. Is there an easy way to distinguish a frontier as being super charged? Obviously if there's a picture of the engine I can tell easily, but often on places like craigslist there isn't. Do you guys have any suggestions for search keywords? I've been using "nissan frontier crew cab" to sift out all the non-crew cabs, but how can I narrow it even further to the supercharged ones? I've tried adding "sc" or "super charged" but I usually only find one or two trucks in the entire southwest. Any tips there would be appreciated.
I've been browsing craigslist, cars.com, and ebay. I doubt I'd buy a car from ebay, but it's worth looking at now and then. Anybody have any other sites I should hit up?
Thanks a bunch guys!
Back to Top View RedFive's Profile Search for other posts by RedFive
dannyg
Posted: Jul 24 2008 at 4:13pm | IP Logged Quote dannyg
Dannyg here I beleave TRUCK TRADER .COM might help why a super charged one the SC i beleave is a 190-205 motor stock to a 177-180 regular stock motor and with the regular motoe u can run low grade fuel instead of hi test fuel
06 frontier 4.0 auto
RedFive
U.S. - Arizona
Posted: Jul 24 2008 at 4:42pm | IP Logged Quote RedFive
Hmmm, I didn't think about having to use 91 octane. That's a good point you make. Is there a higher or lower mpg with the s/c motor?
Frontyfan
Posted: Jul 25 2008 at 12:36pm | IP Logged Quote Frontyfan
The EPA estimates on the S/C or the SVE badged Frontiers in the  years they were supercharged is only slightly lower than the naturally aspirated VG33E. If you check www.nissanhelp.com it wil also give you a lot of information for the different trims of the Frontier for these years up to current models. IIRC, the S/C, and SVE models (SVE, being a supercharged value edition model) was rated at 14-15/and 19-20 for city/highway respectively, and the non-supercharged motor's were rated at 16/20. I could be off slightly, but that site will help you as far as those rating. Dannyg is correct in that you would be "forced" to use premium fuel, or 91 octane as anything lower than that and you risk damaging the knock sensor I believe.
I would refine searches by S/C or SVE if you can in the model name. Also to see the difference if it has pics of the engine, the intake manifold would definitely be diff and you will see the blower on top the motor. This is a pic of a newer frontier with a charger on it (aftermarket) but it will look similar on the older frontiers (the charger that is), it is the silver thing on top of the engine in the picture, you can click on the picture to enlarge it. https://www.4x4parts.com/catalog/product_info.php?cPath=367_ 433&products_id=4511
hope that helps.
'01 SE CC Shortbed silver
dannyg
Posted: Jul 26 2008 at 1:13am | IP Logged Quote dannyg
Dannyg one more to check out is carfax.com
