Subject Topic: 20 inch wheels and tires Post ReplyPost New Topic
wizard12
Posted: May 18 2008 at 3:30am | IP Logged Quote wizard12
my 02 frontier xe has 20 inch rims an 265/50/20 tires on it. some say it will be a problem, nissan says no problem. tires do rub a bit on u turns and i did just replace most of the front end at 86000 miles. any thoughts on this? by the way the wheels were on the truck when i bought it.
Back to Top View wizard12's Profile Search for other posts by wizard12
Boomer
Posted: May 18 2008 at 5:01am | IP Logged Quote Boomer
One comment.  If you offroad or use your truck as a truck, the low profile side walls will be problematic, IMHO.  I prefer a 70 or 75 profile to give me a higher sidewall capable of absorbing more shock and stress.  If you are strictly a street driver and don't run over really bumby stuff like very bad railroad crossings, you'll be fine, however.
A friend with a BMW with the low profile sidewalls went over a RR crossing and flatted two tires!  They were actually damagd beyond repair and cost him about $500 to replace.  He wrote to Norfolk and Southern and didn't they send him a check and an apology!  However, most instances of this will simply end up costing you money.
2007 Nissan Frontier SE 4X4
Posted: May 18 2008 at 5:07pm | IP Logged Quote lakota
Low profile tires on tall wheels is the way to go but you need to buy a yellow suit and a fur coat to go with it. And don’t forget to wear a shower cap while driving down the street.
I judge a mans IQ by the profile number on his tires.
Opssssssssss mine's only 75...
Can you spell facetious?
