Subject Topic: tire size Post ReplyPost New Topic
ramos
Posted: Mar 13 2008 at 4:38pm | IP Logged Quote ramos
no i prob have done a search but... would changing the tire size affect the ride/milage/sound quality. these trucks use 275 which r pretty thick for the size truck.
would going to a 265 make a difference.  offcoarse the percentage would change as to make sure that the whole tire diamater doesnt change just the thickness of the tire
2004 4x4 crew xe
Back to Top View ramos's Profile Search for other posts by ramos
Posted: Mar 13 2008 at 10:52pm | IP Logged Quote lakota
ramos;
Here are some links to help explain a few things about tires and wheels;
WHEELS and Back Spacing
TIRE PRESSURE 101
Why is it that the politicians in D.C. are the only ones that don’t know there are better things to make Ethanol out of than corn?…  Answer… They know! They know! Guess why they don’t correct the problem.
dannyg
Posted: Mar 14 2008 at 3:49pm | IP Logged Quote dannyg
dannyg here difine thick for me cause i went from a 265/70/16 to an lt 265-75-16 with a c load range ride is fine everyone told me that it was only an inch differance but seems like its a 2-3 inch differance the 265-75-16 32-9.50-16 is what the shop said aboult the ltx ms on my truck btw the middle number tells alot about tire size to
06 frontier 4.0 auto
ramos
Posted: Mar 15 2008 at 5:17pm | IP Logged Quote ramos
the first number is how thick it is in meteric. not sure if its cm or mm or something liek that.  the 2nd number is the thick ness of the tire wall compared to the width of the tire. so 265/70r15 is 70% of 265= the height of the tire wall.
2004 4x4 crew xe
Posted: Mar 15 2008 at 9:07pm | IP Logged Quote lakota
... Sorry guys I thought I had more info in those articals than there was...
Here is a nice tire size link... I use it myself...
http://www.discounttire.com/dtcs/infoTireMath.dos tire CALCULATOR
http://www.4lo.com/calc/gearmetric.htm   tire CALCULATOR #2
