Subject Topic: Nissan frontier wheel questions Post ReplyPost New Topic
Jglisson
Posted: Mar 08 2008 at 7:35pm | IP Logged Quote Jglisson
I have a 2000 Frontier 4x2 CC.  I am looking at my wheel options, but from what I have gathered from my search is that there are few options.  I do have a couple questions that I am hoping some of you could help me with.
1.  Are the lug/bolt patterns the same on all the year Frontiers?  Will any design Frontier wheel fit on my 2000?
2.  Will the Nissan Exterra or Titan wheels bolt up?
I have the factory 15 steel wheels and would like to upgrade to something a little nicer.
Back to Top View Jglisson's Profile Search for other posts by Jglisson
Posted: Mar 10 2008 at 5:20pm | IP Logged Quote lakota
Jglisson;
Finding exact Wheel specifications has been difficult.
Here is a paste-up list of some the things needed for comparing wheels.
Dia – width – lug pattern – back space – centering hole size - lug/hub centric? – lug style – lug size -
Titan Bolt pattern is 6-5.5" also listed as 6-139.7mm sometimes.
Weld's wheels application catalog references Titan hubs as 3.072” HUB I.D
The 1999 Frontier Se cast aluminum 4x4 wheels are hub-centric, 6 lugs on 5.5” dia., 15”dia. X 7” wide, 5.250 Back Spacing, centering hole is 3.925 inches in diameter... these are my measurements.
Incomplete info below:
http://www.okoffroad.com/editorial-boltpattern.htm
