Subject Topic: ’05-’08 bed rail insert stops Post ReplyPost New Topic
DarrenC
U.S. - North Carolina
Posted: Feb 19 2008 at 8:33am | IP Logged Quote DarrenC
I know that subject is clear as mud, but I have a fairly new to me '07.  I've never had the bed rail inserts out (the black things that slide into the rails).  I hauled a treadmill over the weekend and broke off some kind of stops or something that was holding them from sliding back and forth.  Now the inserts slide back and forth when I accelerate and brake.  They only slide about 6 inches or so before they hit the tailgate, but it's annoying.
Anybody know what I broke and how to fix it?
Thanks.
2007 Nissan Frontier SE 2WD Crew
2005 Specialized Stumpjumper Expert
2003 Honda VFR800 Interceptor
Back to Top View DarrenC's Profile Search for other posts by DarrenC
DrKwan
Posted: Feb 20 2008 at 12:12pm | IP Logged Quote DrKwan
Mine slide about 1 inch so it is possible your covers were cut at some point.  You could try using those little "lock" thingies that just bolt on.  They came with my tie down set.  If I were you, I would just cut a small piece of black foam and squeeze it in the track.
Good luck.
Chance favors the prepared mind
Back to Top View DrKwan's Profile Search for other posts by DrKwan
DarrenC
Posted: Feb 21 2008 at 7:46am | IP Logged Quote DarrenC
I found 4 little black square pieces in the bed that look like they were broken off the rails or something.  I can't find an exploded parts diagram on the internet so I guess I'll have to go with my last resort and ask the dealer...
GSTtex
Posted: Feb 21 2008 at 8:30am | IP Logged Quote GSTtex
i had the same problem with mine.. somehow the little black wheels that slide back and forth in the railing, came out the end. well one wheel did. i have no idea how to get it back on.. its a major pain, and i cant see how in the world the wheel came out..
2007 Frontier SE
1996 Spyder GS-T
Back to Top View GSTtex's Profile Search for other posts by GSTtex Visit GSTtex's Homepage
slugcatcher
Posted: Apr 16 2008 at 12:05pm | IP Logged Quote slugcatcher
They're a molded part of the rubber slide protectors. They are at the very end of the part. They can't be replaced without replacing the whole protector. If it bugs you that much take them off and add a little black RTV where the stops where and let it dry overnight before you reinstall. That should give enough friction to keep them from sliding.
Back to Top View slugcatcher's Profile Search for other posts by slugcatcher
