Posted: Feb 09 2008 at 11:16pm | IP Logged
surfahjammer;
… I had a ’01 Sentra with fogged up lenses. I wet sanded them with #600 wet/or/dry then used the white fine compound to finish polishing them out. It took six hours but it made the car more valuable when I traded it in. Auto parts places have kits for doing it. If you use a machine polisher be careful to not burn the plastic… good luck… I think some car waxes damage the plastic..
Tip of the Month … Keep a fire extinguisher handy…even if it is not a Ford…
