Posted: Nov 25 2007 at 11:11pm | IP Logged
jon;
Are you talking about 16 inch wheels?
A. It is the diameter and width of the tire that you have to worry about for clearance not the rim size. Too small of a rim could rub the brake calipers. The wrong Back Spacing of the rim can cause problems.
B. Tires for 16 inch wheels as a rule cost more that those for 15 inch wheels.
C. Comparing 15 to 16 inch rim size tires of the same diameter the 15s will have a better spring rate and will ride better, and air-down better for better traction when needed.
