Posted: Jul 16 2007 at 4:53am | IP Logged
MrJodie wrote:
snip ...and I don't like the thought of an exploding bag rushing up to kiss me should I hit something.
Is the thought of being slammed into a non-squishy steering wheel and possibly being impaled by the steering collumn more comforting?
Here's a little thought for you... your truck is designed to act a certain way in the event of a collision. The airbag is an intricate part of that design. These trucks are not designed like the trucks from back in the day that would slam into things and limp home. Even minor collisions will render them undriveable. The seatbelt pretensioners tighten up to keep the occupants in place, the front end and fenders will fold up like an accordian while at a specific momment in time the airbag will deploy... all to lessen the effects of the impact on your body. A smart man would not screw with this system. Leave it alone. The old rule of thumb for seating positions is to sit with your shoulder blades touching the seat and stick both arms out towards the wheel... your wrists should be able to rest on top of the wheel.
Also, I'm pretty sure that should you remove or otherwise disengage the airbag that the warning light on the dash will stay on indefinetly.
Nate
__________________ '07 Frontier CC LB SE 4x4 6spd
'72 Datsun 240Z
'05 Sentra S (SE)
