METRONISSAN Newbie
Posted: May 17 2005 at 12:13pm | IP Logged
DOES ANYONE HAVE A SOURCE ON REAR SLIDER WINDOW FOR '05 CREW CABS?
Pick up Newbie
Posted: Apr 20 2007 at 10:45am | IP Logged
I thought the factory glass from the King cab would fit...?
Pick up Newbie
Posted: Apr 20 2007 at 11:07am | IP Logged
METRONISSAN wrote:
DOES ANYONE HAVE A SOURCE ON REAR SLIDER WINDOW FOR '05 CREW CABS? |
---------------------------------------------------- Here is a link for a power slider...
http://aztrucks.com/Product.asp?Product=94
There was a post on another forum that showed the install on a frontier, he said he had to remove the jack and a seatbelt for the motor. Please post if you find a source, I was looking for this as well and thought I could use the glass from the King cab, if not I would be interested in what you find out. I did find this link for C. R. Laurence that seems to be a match, I haven't seen anyone who has tried it.
http://www.crlaurence.com/ProductPages/E/ECT655S_32480.html? Origin=
Pickup Newbie
Posted: May 03 2007 at 5:27pm | IP Logged
Ok- I can confirm that the slider used in the KC will fit in the 2006 CC without modification. There is no defroster option but the increased air flow is worth the trade off. Also, for those who have expressed a problem with the wind noise/buffeting I will tell you that it does largely eliminate this condition.
