Posted: Nov 26 2011 at 4:13pm | IP Logged
You can add one leaf to each spring pack or over load coils the the rear shocks. Ether way it will reduce the sag under load but the none load ride will be stiff. Adding one inch blocks will help a little. I did it to my '99 with good results. Carrying the heavest part of the load as far forwared as possible helps.
BTW.. Use new U-Bolts when / if changing the springs. Nissan has a different shape than some so check it out before you spend some money!
Good Luck.. Don S..
