Subject Topic: right tire psi for non original tire Post ReplyPost New Topic
u157391
Posted: Jul 21 2011 at 2:03pm | IP Logged Quote u157391
Hi,
My 2003' frontier's original tire size is 225 70 r15 but currently it has 225 60 r15.
My question is anyone knows how much psi should I have to filled in. I saw on the door label but it only indicate 30psi for 225 70 r15 sized tire.
Thank you in advance...
Back to Top View u157391's Profile Search for other posts by u157391
Posted: Jul 21 2011 at 4:23pm | IP Logged Quote lakota
Welcome to the group!
The rated tire pressure is usually for the tire type/size/model/load range that the truck was equipped with at the factory. One rule of thumb states a smaller tire needs a little more pressure to carry the same load. I’d put 30 lbs in them and keep checking the wear pattern.
Good luck.. Don S..
u157391
Posted: Jul 21 2011 at 6:41pm | IP Logged Quote u157391
i will keep with 30psi.
thank you for your help.
