Subject Topic: 2004 Nissan Frontier Tires Post ReplyPost New Topic
s2002h69
Posted: Oct 26 2007 at 6:24pm | IP Logged Quote s2002h69
Hi,
I have a 2004 Nissan Frontier XE Crew Cab 4wd with an original tire size of 265/70-15. I wanted a bigger tire to give it a more rugged look, it was suggested to put on 31X10.5-15 size tires. Has anyone done this and, if so, did they fit well (within the wheel well, etc ...)? Did you experience any problems?
Thanks
Back to Top View s2002h69's Profile Search for other posts by s2002h69
Posted: Oct 26 2007 at 10:51pm | IP Logged Quote lakota
s2002h69;
The departure angle is a problem with the Frontiers. I run mild trails like Black Bear Pass in Colorado and only need a little lift but do need better departure angle. I cranked the T-bars 5/8th inch, added one inch blocks to the rear and BFG AT-KO 31x10.50x15 tires. The truck sets high in the back and gives a slightly better view of the jagged rocks on the trail in front! After looking at it I could see the departure angle still need help. I removed the rear bumper as it protruded out much farther than the bed. Then added the Cass III hitch to help protect the sheet metal and mount a tow hook.
This Frontier has done many mountain trails and passes in Colorado. The wife and I sleep in back once per trip.
sams2000tier
U.S. - Virginia
Posted: Oct 28 2007 at 3:58pm | IP Logged Quote sams2000tier
i put 31x10.50 bfg all terrains on my stock frontier with no problems at all
if you are looking for a more rugged look go for a mud terrain interco
makes great looking tires that dont cost too much and are reliable
Back to Top View sams2000tier's Profile Search for other posts by sams2000tier
Posted: Oct 28 2007 at 6:16pm | IP Logged Quote kcidmil
It all depends upon what Interco you're going for.  Don't be too fooled, some of those are meant only for off-road.
s2002h69
Posted: Oct 30 2007 at 10:29am | IP Logged Quote s2002h69
Ok, thanks for the info.  So, if I went with a BFGoodrich All-Terrain T/A KO tire in a 31X10.5-15 size, I shouldn't have to make any modifications to the truck?
sams2000tier
U.S. - Virginia
Posted: Oct 30 2007 at 12:35pm | IP Logged Quote sams2000tier
i didnt have to make any     when i turned real hard to the right it rubbed
just a little bit but i used a knife and cut about 1 square inch off and it never
rubbed again
