Posted: Aug 30 2007 at 7:18pm | IP Logged
just imagin what it sounds like with The Nismo headers... that ... sounds truly amazing! it makes that consistant whistle alil lowder, and you can hear the cyl definition alot more than you already noticed that you can. the factory cross pipe has quite the sound dampening chamber in it.
BE CAREFUL, that bolt that holds up the pipe so the filter floats in the cold air box... comes loose... make sure you used some type of thred lock... because it will vibrate loose.
__________________ It may not be big, but i can sure get in and out of some tight places.
84 300ZX-T
89 240SX coupe
06 nismo frontier
