TRDeeze!!! Newbie
Posted: May 31 2007 at 6:07pm | IP Logged
I just installed a Top Gun Customz 2 1/2 inch leveling kit in my 06 4x4 and put on some Nitto terra Grappler 285/75 16. I brought it to a local alignment shop to get er pointing in the right direction. I noticed the next day that the camber was off (the tops of the wheels pointed outwards in relation to the bottoms, noticable when viewed from the front). I was wondering if anyone else had this problem and if it is merely the shops error or if there are necesary parts or kits to buy th rectify this problem. I'm bringing it back to the shop soon to see what they have to say as I dont want to fry my new tires. Thanks for any help antone can give!!
__________________ 2006 SE King Cab 4.0
Injen C.A.I.
Gibson Cat Back
Top Gun Customz Leveling Kit
Calmini 2" Shackles
Nitto Terra Grappler
285/75 16
EB_05_NISMO Groupie
Posted: Jun 01 2007 at 8:02pm | IP Logged
I responded in your other thread here:
http://nissanfrontier.org/forum_posts.asp?TID=1441
TRDeeze!!! Newbie
Posted: Jun 18 2007 at 5:19pm | IP Logged
Problem solved!! The camber adjustment bolts were, for some reason slipping and not holding the front end in alignment. After having the front end disassembled to look for damage and finding none, it was reassembled and aligned and now works perfectly. Ahhhh.
Injen C.A.I.
Gibson Cat Back
Calmini 2" Shackles
285/75 16
