Subject Topic: VDC OFF after installing K&N 77 CAI Post ReplyPost New Topic
madmanhiker
Posted: May 16 2007 at 7:23pm | IP Logged Quote madmanhiker
I just finished installing the K&N 77 CAI and while I was pulling out the stock airbox, and there was a tube that for the life of me I cannot figure out where it goes. I looked on the stock air box... can't see where it hooked up.... after installing the 77 CAI, there was only one hose and that was for the crank case vent.  I started it up, and noticed an idiot light for 'VDC OFF' so, this tube MUST go somewhere. I have a 2006 Frontier 4.0 LE 4x4
Here is a pic of the unconnected hose. This is driving me nuts! Thanks in advance.
http://www.madmansarchive.com/where_does_this_hose_get_conne cted.jpg
Back to Top View madmanhiker's Profile Search for other posts by madmanhiker Visit madmanhiker's Homepage
EB_05_NISMO
U.S. - Connecticut
Posted: May 16 2007 at 9:16pm | IP Logged Quote EB_05_NISMO
That tube is the front differential breather tube. I just used a cable tie and tied it to the ABS lines (see pic below). I don't have VDC, but I don't see how the hose would affect it. The only thing I can think of that caused VDC to turn off is that you disconnected the negative terminal on your battery and it most likely reset the electronics after putting it back on.
2005 Electric Blue Nismo King Cab 6spd 4x4
Back to Top View EB_05_NISMO's Profile Search for other posts by EB_05_NISMO
madmanhiker
Posted: May 16 2007 at 10:19pm | IP Logged Quote madmanhiker
Thanks for the response. Yes, I figured that out after following the tube down to the front diff. Strange... I took the truck out for a spin and the VDC error went away.... I guess it was just a glitch that required some time for the computer to reste after reconnecting the battery.
Good idea on the zip strip.
