Posted: Dec 06 2011 at 3:59pm | IP Logged
Wet roads should be OK but I don't do it even for slush. If the tire treads are on packed snow the 4WD will be good and help you go... BUT you can't stop any better than in 2WD!!!!!
It may let you climb an over pass but then you may not be able to stop on the other side!!!
Have a warm one.. with a marshmellow.. Don S..
