Frontier Off Road 4x2/4x4
Subject Topic: double wisebone suspension Post ReplyPost New Topic
Coyote
Posted: Jul 27 2011 at 4:08am | IP Logged Quote Coyote
My 2011 Frontier Pro-4X is pretty well loaded but the front suspension is a double wishbone. A club member of our local off-road club had a Nissan Hardbody with independent suspension and said they broke constantly. I am only familiar with straight axles on my 55 Willies n 90 Wrangler. I am only planing on doing class 1 or 2 trails. Input would be appreciated. Thanks, Coyote
Back to Top View Coyote's Profile Search for other posts by Coyote
Posted: Jul 27 2011 at 4:34pm | IP Logged Quote lakota
One trick about driving independant front end is to let off the brakes just before you hit a bump. this lets the front end rise and gives more ground clearance for the differentual housing. Hard Bodies and early Frontiers have steering links that are a little weak. Pick ups need a little more lift in the rear than the front.
Good Luck..Don S..
Coyote
Posted: Jul 27 2011 at 5:19pm | IP Logged Quote Coyote
Don thank you. I would have not figured that one out. Coyote
