Frontier Off Road 4x2/4x4
Subject Topic: Max tire size on stock 01 SC Post ReplyPost New Topic
muddriller33
Posted: May 21 2011 at 6:49pm | IP Logged Quote muddriller33
I was wondering if anyone knows the max tire size you can fit on the stock 17 inche rims on the 01-04 4x4 crew cab sc models? i believe the tag on the door says 265 R17 55 possibly, but i'm wondering if I can fit a set of 265 70's on there?
any advice would be great,
cheers
Back to Top View muddriller33's Profile Search for other posts by muddriller33
Posted: Jul 11 2011 at 4:16pm | IP Logged Quote lakota
Discount tires has a size conversion guide that can tell you the diameter size increace. Cranking the 'T-bars' one inch or less and maby mild trimming should give enough clearance. If the T-bars are cranked up have the front end alighnment checked.
Good luck.. Don S..
