Subject Topic: New 2006 Issue ..need some insight Post ReplyPost New Topic
akpsibro
Posted: Nov 10 2006 at 2:50pm | IP Logged Quote akpsibro
Ok I just purchased a new crew cab 4x4 se and I have had it in the shop 5 times now for the same issues. I wanted to see if others are having teh same problems.
Ok first issue is my ac..after accelerartion the and sounds like it releases pressure everytime. It almost like a whisling sound. I have been told its the expansion valve but they are not sure if that will correct the issue so the dealership will not fix it.
Two... When driving at speeds between 20-30 mphs I here a thumping noise it sounds like a bad shock but that has been ruled out. The tech said it sounded like its from the transfer case but he is not sure and the dealership just keeps leaving it at that.
Are any of these issues happing to your vehicles? Please help
Back to Top View akpsibro's Profile Search for other posts by akpsibro
Posted: Nov 11 2006 at 1:30pm | IP Logged Quote lakota
akpsibro;
... Welcome to the group!... Sorry to hear of the problems with the truck and dealer.. Options are:
1. Go to another dealer
2. Talk to the General Manager of the dealership. Ask if he thinks you should talk to an area Nissan factory representative. In this case a squeaky wheel might get oiled!
Nissan is well aware of the importance of good consumer relations. Business people are now beginning to notice the effects caused by complaints on the Internet.
Have a good one,   and  CUL.. Don S..
Hugh B
Canada
Posted: Nov 13 2006 at 9:53am | IP Logged Quote Hugh B
This may not help your situation but it's a good site to be aware of.
http://www.nissanhelp.com/
Hugh
06 Crewcab LE leather
'00 Audi S4 6sp
Back to Top View Hugh B's Profile Search for other posts by Hugh B
