Subject Topic: New member with temp problem Post ReplyPost New Topic
Pntball&wheelin
Posted: Oct 04 2006 at 4:49pm | IP Logged Quote Pntball&wheelin
I just purchased a 2001 frontier 4dr 4wd with 3.3 non s/c. It overheats at idle when level or facing up hill, but not when facing downhill. It is full on coolant, blows lots of hot air, and cool right down while moving. Any ideas???
Also I read the codes and it comes up with emmissions (I believe it to be a O2 sensor) and with a knock sensor code.
Any help?????????
Lift it cause fat chicks can't jump
Andy
Back to Top View Pntball&wheelin's Profile Search for other posts by Pntball&wheelin
blackmagicx
Posted: Oct 17 2006 at 8:09pm | IP Logged Quote blackmagicx
try changing out your thermostat and flush your coolant.
Back to Top View blackmagicx's Profile Search for other posts by blackmagicx
