Subject Topic: replacing knock sensor ??? Post ReplyPost New Topic
slackmaster
Posted: Sep 06 2006 at 1:39am | IP Logged Quote slackmaster
ok so i have a 2001 sc frontier and i am tired of changing the knock sensor i heard that i can just hard wire in a resisator........gut  what size?
my nissan is called CLUNKY
Back to Top View slackmaster's Profile Search for other posts by slackmaster
Frontyfan
Posted: Sep 06 2006 at 11:22am | IP Logged Quote Frontyfan
i'm assuming you have taken it to the dealer if this has been a recurring problem, if not, that might be a good idea.....but first..what grade gas you feeding your S/C? from what i've heard if you are feeding it anythign but the premium stuff you will do your knock sensors in quick
'01 SE CC Shortbed silver
slackmaster
Posted: Sep 06 2006 at 12:30pm | IP Logged Quote slackmaster
well it only gets the best ....premium grade chevron.  I am really tired of this thing falling on its face after about 20 min of driving time
Frontyfan
Posted: Sep 06 2006 at 12:57pm | IP Logged Quote Frontyfan
yeah i like the chevron too..but since i'm not in an S/C it gets the regular grade unles i go for mid grade now and then..but i try to every 3-4 months like the nissan guy told me...dump a tank of premium in there with BG44K to clean the fuel system up..which could very well be a ploy to sell me BG44K since i only seem to find it at the nissan dealer at 16 bucks/can but well i guess it is a good thing to do..it's the same stuff they use to clean injectors out...i'd just say take it to the dealer man...i tried to do a little research with no luck but i'm limited on time right now
slackmaster
Posted: Sep 06 2006 at 2:15pm | IP Logged Quote slackmaster
well thanx for the info i will try the BG44K first abd see what happens
