Subject Topic: P0455 Problems Post ReplyPost New Topic
bill b
U.S. - New Hampshire
Posted: Jun 11 2019 at 8:43am | IP Logged Quote bill b
Hi, Everybody,
I've had this code since I've owned the truck. I changed the vent control valve but now, after smoking it and seeing the leak, I rechecked the voltage and there's only 10V at the connector. Is there any simple way...?
Thank you.
Bill
Back to Top View bill b's Profile Search for other posts by bill b
Posted: Jun 11 2019 at 5:31pm | IP Logged Quote frontierguy
what is your battery voltage? Possible corrosion in the
main harness or SMJ behind the LF tire.Need more info-
yr-miles etc.
