Subject Topic: 17 Frontier AT Sticking in Gear Post ReplyPost New Topic
wampster
Posted: Aug 13 2018 at 2:33pm | IP Logged Quote wampster
Hi,
I have tried searching for this an not sure if I am misspeaking or what so
apologies if this has been brought up earlier.
I have a new 2017 Frontier S 2WD with the automatic 4 cylinder. When I am
am going from a stop or low speed to 45 mph or so, 8 times out of 10 the gear
I am in to get to 45 will stick at around 3000-4000 rpm and not up shift to the
high gear.
It doesn't seem to matter if I let off the gas a bit or take my foot off, it will stick
in that passing gear for several seconds. This will happen every time that the
direction I am going is on an incline.
Its only happening at that 45 mph spot. If I push to 55/60 it will shift, or if I
crawl up to 45 it will not stick.
It does the same thing for multiple drivers too. I am a gas mileage guy, so I am
not stomping on it or anything (hey its a 4 banger in a big truck, it aint sporty).
Has anyone else had this happen, I am trying to gather some info before
heading into the dealer.
Back to Top View wampster's Profile Search for other posts by wampster
Posted: Aug 13 2018 at 2:44pm | IP Logged Quote lakota
Sounds like a computer or sensor - dealer issue.
Good luck with it.. Don S..
