Subject Topic: 4L 2009 Nissan Frontier Overheating Post ReplyPost New Topic
Lappnathan
Posted: Jul 30 2015 at 6:44pm | IP Logged Quote Lappnathan
Cooling sys. pressure tested. New T'stat installed. New
Rad caps installed. Blows water out of reservoir
Nathan L Lapp
Back to Top View Lappnathan's Profile Search for other posts by Lappnathan
Posted: Jul 30 2015 at 7:56pm | IP Logged Quote lakota
I haven't had one over heat in over 20 years.. So I forgot every thing about it that I ever knew...
COOLING
Knowing the driving conditions that are causing the problems can help pinpoint the proper solutions.
First the coolant
Has the cooling system been completely purged of air including the heating system?
Is the coolant the proper type and mix fresh and consistent with manufactures    recommendations?
Is the over flow bottle at the correct level when hot and cold?
Mechanical
Is the pressure cap maintaining pressure?
Are all the passageways in the radiator core flowing properly free of crud?
Is the coolant pump pumping at full capacity?
Are the impellers or housing in the pump eroding or cavitating?
Is the drive system for the pump slipping?
Is the thermostat working correctly?
Is the cooling fan stock, the drive system and thermal sensing system working properly?
Is the heater system connected to the coolant system as it should be?
Is the A/C or automatic transmission add more than normal heat to the system?
Is the lower radiator hose being sucked closed without a large coil spring in it?
Air Flow
Is there ‘bug juice’ mud or the wrong type of paint on the cooling core?
Is the grill, bumper and air dam stock and in good shape?
Bad tuning of the engine like wrong ignition timing or wrong fuel/air mixture ratio.
Bug screens, add on lights or recovery winches in front of the radiator core
Brakes dragging
Running in the wrong gear.
Helpful do it yourself cooling tricks
Add hood bug/rock shield that forces more air into grill
Add a larger air dam below bumper that forces more air into grill and helps suck hot air from under the hood.
Add an automatic transmission pre-cooler behind the cab or completely reroute the system behind the
cab to remove the added heat from in front of the radiator core
Reverse flush the radiator core with a garden hose in the lower/output hose.
Using mild pressure wash the bugs and stuff from the radiator core squirting from the back side.
NOTE…
If all else fails turn off the A/C, turn on the heater, roll down the windows and slow down!
Good Luck.. Don S
Yooper
Posted: Jul 31 2015 at 6:11pm | IP Logged Quote Yooper
I had this happen to a couple of cars and it was a head casket.
Yooper Scooper
Back to Top View Yooper's Profile Search for other posts by Yooper
Rubble
Posted: Aug 01 2015 at 3:16pm | IP Logged Quote Rubble
That's what I am thinking too ^^^^.
Take radiator cap off,, and with the motor running check for bubble's.  Bubble's are an indatation of Head Gasket leaking.
Barney
