Subject Topic: 06 4 wheel drive nismo Post ReplyPost New Topic
charger490
Posted: Aug 27 2014 at 11:49am | IP Logged Quote charger490
put truck in 4weel drive low and pulled a bush out in reverse and the truck stayed in low what can i do now
66 dodge charger
68 dodge charger
58 plymouth
97 honda crx
2001 honda crv
2006 frontier
Back to Top View charger490's Profile Search for other posts by charger490
Posted: Aug 27 2014 at 9:35pm | IP Logged Quote lakota
Manual or Automatic Trannie...?
Good Luck.. Don S..
charger490
Posted: Aug 30 2014 at 3:06pm | IP Logged Quote charger490
  automatic
66 dodge charger
68 dodge charger
58 plymouth
97 honda crx
2001 honda crv
2006 frontier
Posted: Sep 04 2014 at 9:02am | IP Logged Quote lakota
Sorry I couldn't help with the problem. I was hoping some one else might have some ideas.
Take care.. Don S..
charger490
Posted: Sep 04 2014 at 3:29pm | IP Logged Quote charger490
i had a friend get under and pound on the motor while i used the switch and i have been doing that 4  times. i have it in 2 wheel drive now but am going in for a oil change so will work on it to see if it frees up other wise will go to dealer. 600.00 for a new motor for the 4 wheel drive.thanks don
66 dodge charger
68 dodge charger
58 plymouth
97 honda crx
2001 honda crv
2006 frontier
charger490
Posted: Sep 08 2014 at 5:21pm | IP Logged Quote charger490
well i read the book and it said push on the brake when you change the switch from 4 wheel to 2 wheel and it worked.solved the problem
66 dodge charger
68 dodge charger
58 plymouth
97 honda crx
2001 honda crv
2006 frontier
Posted: Sep 08 2014 at 9:34pm | IP Logged Quote lakota
Wow... I never would have thought of that. It's almost like reading directions when building a kids toy...
My '99 has the old school 4x4 shift lever.
I often worry about the automatic front hubs disengaging but it always has.
Glad it's working.. Don S..
davidjbrady
Posted: Sep 09 2014 at 6:09pm | IP Logged Quote davidjbrady
That's good to know, thanks for sharing. I saw that in the owners manual as well, and I have done that in the past, I thought it was there for safety's sake.
Thanks,
David
08 Frontier CC, 4X4, LWB
Posted: Sep 10 2014 at 8:16pm | IP Logged Quote frontierguy
also the trans should be in neutral, wheels steered
straight ahead. after a hard pull and using on dry ground
it may "BIND" the transfer, backing up to relieve the
strain helps also.
