04frontiergirl Newbie
Posted: Jun 27 2014 at 8:29am | IP Logged
I have a 2004 Frontier XE, 4WD, Crew cab. The service engine light started coming on and going off in early April. I finally took it in to the dealership on Monday and the only code they found was a P2328, knock sensor. Service advisor thinks this is masking another problem since there were no other codes given. He even asked me if I cleared them. WTH?
Anyway, the estimate was $411 parts, $450 labor. They'll change the sensor out and I get to hope there isn't some other problem.
Two local mechanics told me nobody puts knock sensors on their trucks anymore, that the practice was stopped in 2003-2004. Both estimates were less than the dealership's.
I'm not having any other problems except an occasional burnt sweet smell that I notice after running errands. I don't have any visible puddles in the garage or on any pavement when I am parked.
Any thoughts about whether the knock sensor is critical? The dealership said that failing wouldn't make the SES light come on. Do I leave well enough alone and keep an eye out for leaks? My truck only has about 38,000 actual miles on it.
Thanks!
Posted: Jun 28 2014 at 10:55am | IP Logged
IMHO
It would seem if you use quality fuel and don’t carry or
pull heavy loads you might be OK with it.
I have read pre-ignition is harder on these modern
engines. Never heard it on the modern engines but it’s a
rattling sound in the old ones.
Dealerships have to charge a higher hourly flat rate due
to higher overhead. In most cases they are a lot more
familiar with the vehicles they service.
Good Luck.. Don S..
Posted: Jun 30 2014 at 8:42pm | IP Logged
It is just under 4 hrs for the repair. The knock sensor,
int. gaskets(2), int plenum gasket and 6 lower injector
seals, I would hope do not cost $411!!!!! But then, some
dealers use the "matrix" parts pricing system that makes
the prices crazy high. Our labor rate is $80/hr, small town
in upstate Pa.
