Subject Topic: oil leak Post ReplyPost New Topic
frontiermarge
Posted: Jan 31 2014 at 8:03am | IP Logged Quote frontiermarge
Hi, i have a 2001 frontier 3.3L.  I have an oil leak that  collects in my bell cover housing.  i recently replaced my starter and there was a small but constant stream of oil running.  I have replaced the valve cover gasket and the oil leak remains.  I called nissan and they said that is rare for the rear main seal to leak, but they would not give me any information as to where the leak might be,
Please help.
Back to Top View frontiermarge's Profile Search for other posts by frontiermarge
Posted: Jan 31 2014 at 6:30pm | IP Logged Quote frontierguy
There is a gasket on the rear main seal retainer that will
suck in and create a leak, either way the trans will need
to come out(easier to pull the trans instead of the
engine). I have also seen the oil pans leak in the left
rear corner.
frontiermarge
Posted: Jan 31 2014 at 6:47pm | IP Logged Quote frontiermarge
Oh no, that sounds expensive.
Thanks for the info.
