Subject Topic: VQ engine idle Post ReplyPost New Topic
davidjbrady
Posted: Jan 16 2014 at 8:51pm | IP Logged Quote davidjbrady
Hello, I have the 2008 V6, wanted to know if it really is possible to go to the dealer and have them set the idle to like 750 RPM. I did the idle learn procedure (non hand held consult process), that did not help one bit, having engine chatter and if I make a turn at idle like in parking lot, I can feel the power steering pump bringing the idle down, the same can be said when the AC is on. I am not getting any trouble codes either, telling me all is good.
Is the idle set to a default like 650-675 RPM?
Other than that, all is fine and dandy, just hit 62K miles.
Thanks!
08 Frontier CC, 4X4, LWB
Posted: Jan 18 2014 at 7:40pm | IP Logged Quote frontierguy
Might want them to "clear the self learn", then perform
the IAVL. The idle can be set higher if needed after that.
I would ask them to do the 2 degree timing advance also.
