Subject Topic: thermostat p1126 Post ReplyPost New Topic
frontiermarge
Posted: Jan 11 2014 at 7:53pm | IP Logged Quote frontiermarge
Hello, I had an error code p1126 and I replaced the thermostat, but the check engine light stayed on.    The temperature gauge seems to read normal.  It is  slightly below the mid position.    Does anyone have a clue as to when the check engine light will go off?  Please help
Back to Top View frontiermarge's Profile Search for other posts by frontiermarge
Posted: Jan 13 2014 at 8:16pm | IP Logged Quote frontierguy
It usually takes 50 trips(engine cold, engine rises above
158 F, engine cools down) or you could go to AZ have them
scan and erase the code if that concern has been
corrected.
