10ecjed Newbie
Posted: Oct 14 2013 at 9:38pm | IP Logged
2012 Frontier. I can not figure out how to adjust the head lights down. I am blinding everyone, especially with a load. I looked through the site but could not find it. Please forgive me if I missed the info. Thank you
__________________ 10ecjed
Posted: Oct 16 2013 at 10:08am | IP Logged
Sorry that no one has yet had an answer to your question..
Yet. This post will bring it back to the top.
Thank you for having concern about the on-coming
drivers!
Good Luck.. Don S..
2004offroad Newbie
Online Status: Offline Posts: 34
Posted: Oct 17 2013 at 9:16pm | IP Logged
if i remember correctly if you look at the top of the
housing. look to one side i think the closest corner to
finder area there should be a plate to put a Phillips screw
driver and adjust the wheel. its ether a white gear or
black. just be careful on how much you adjust it bc it can
and will affect the light output of your head lights. i
would advise take it to the dealer and ask them to use
their head light aimer to get the proper level. you can
eyeball it on a flat surface and shine it against a wall
and get it about even. get it about 20 ish feet away and i
think the light line should be 4.5-4 ft off the ground (
waist height)
__________________ 04 frontier 4x4
3 inch lift
ac upper control arms with ball joint spacers
hd tie rod and idler arm brace
rancho 5000
32s on procomp wheels
flowmaster duels
