mpbclutch33 Newbie
Posted: Jun 06 2006 at 2:29pm | IP Logged
I have noticed recently a slight whinning noise while driving at slower speeds and goes away when you stop. Truck doesn't act any different just a little annoying. Anyone have this problem or know what it could be.
Posted: Jun 06 2006 at 5:07pm | IP Logged
How slow of a speed? Through which gears? Front or rear?
mpbclutch33 Newbie
Posted: Jun 07 2006 at 6:42am | IP Logged
It almost sounds like a power steering whine, but when you turn the wheel it doesn't get worse or anything. I would say I only hear it with the window down and about 25 mph and under. I may just be nit picking, but I don't ever remember it doing it before. It is just annoying to me
Posted: Jun 07 2006 at 7:22am | IP Logged
hard to say, it could just be the transmission. My Highlander has a whining noise through 1st gear.
mpbclutch33 Newbie
Posted: Jun 07 2006 at 10:26am | IP Logged
I mean it is not to disturbing like something is going to brake or anything, but I know it wasn't making that sound before and now it is. I don't know. I guess I will just keep an eye on it and see if it gets worse. Thanks though
squid vicious Newbie
Posted: Oct 04 2006 at 10:13pm | IP Logged
Mine does the same thing (06 v6). As far as I can tell it's coming from around the driver's side rocker cover/timing chain cover. I don't know what it is, but it's done it for months now with no noticable deterioration in power/mpg and it hasn't gotten worse.
It's RPM related only and is most noticable at slower speeds.
jpgof Newbie
Posted: Oct 05 2006 at 10:50pm | IP Logged
I had something similiar happening to mine ('05 CC Frontier). One day, the whine became constant and much louder. At that point, you could definitely tell it was a belt. Took it in and they said a pull had broken.
__________________ JP3
TheRedRocket345 Newbie
Posted: Oct 27 2006 at 12:13am | IP Logged
ya thats what happend w. me they told that i had replace the pullies an the alternator for 600$ an they voided my engines warrantee because of water damage thats a load of crap
Posted: Oct 27 2006 at 12:15am | IP Logged
oh ya also the sqeakin noise coming from the front, all i did to get rid of that was tight the rubber stoppers an it went away, they pully whinning jus happend to me like i said above
