Subject Topic: Shift to drive or reverse big clunk Post ReplyPost New Topic
trevorg
Posted: May 05 2006 at 10:14pm | IP Logged Quote trevorg
Ive done a search to make sure I am not posting a problem already resolved.
I purchased a 2005 NISMO 4X4, it had 100 miles on it when I purchased it but I got a real good deal
Anyway, when I shift from PARK to Drive or Reverse it results in a drive line clunk, even from drive to reverse and reverse to drive- is this drive line lash? I dont know if this is normail? sometimes it is louder than other times and other times I dont even notice it. I am reallt concerned-
I get no answers from the dealer ship besides "everything is fine"
Thanks for any help
Back to Top View trevorg's Profile Search for other posts by trevorg
Posted: May 06 2006 at 9:15am | IP Logged Quote kcidmil
If if concerns you that much (some vehicles do have a slight clunk) check the drivline U-joints.  You can easily turn the shaft and look for any play (usually one portion of the shaft will rotate more than another part causing a weird angle)
Another possibility is the rear differential, play in there will cause a clunking noise as the pinion turns and contacts the ring gear.
drumbob
Posted: May 09 2006 at 7:53pm | IP Logged Quote drumbob
It may be leaf spring warp. Can be cured be adding helper springs in front of the rear axel. It took my clunk away. Go here for the dicussion
http://www.clubfrontier.org/modules.php?name=Forums&file =viewtopic&t=1510
Back to Top View drumbob's Profile Search for other posts by drumbob
babytitan
Posted: Jun 03 2006 at 9:37am | IP Logged Quote babytitan
thats what I heard and found out it is a leaf spring wrap the cure is at auto zone for a mear 24.95 it is dynachrome leafspring helpers part #18921
Back to Top View babytitan's Profile Search for other posts by babytitan
hsckris
U.S. - North Carolina
Posted: Oct 07 2008 at 11:12am | IP Logged Quote hsckris
Link didn't work for me ?
06 Nissan Frontier KC SE 4x4.
03 Ford Focus ZX3.
