Subject Topic: Instrument panel malfunction Post ReplyPost New Topic
mmgearhead80
U.S. - Washington
Posted: May 29 2011 at 11:39pm | IP Logged Quote mmgearhead80
1998 4WD Frontier SE.  Fantastic rig, almost all stock.  133K miles.  lately, the digital odometer has been reading weird-  double miles, trip only, 999,999, etc.  And when it does, the tach will double the RPM, the speedo will half the MPH.  Or the temp guage and fuel gauge will tweak as well.  Battery is GOOD, cables, connections good.  Truck runs like new except for this intermittent problem.  Anyone?
-Happy Frontier owner
Back to Top View mmgearhead80's Profile Search for other posts by mmgearhead80
mmgearhead80
U.S. - Washington
Posted: May 30 2011 at 11:42am | IP Logged Quote mmgearhead80
After reading in a different forum from people with the same problem with '98 Frontys, I think I fixed it.  Dave posted " check your electrical connection to the inst. cluster or the grounds for it. "  That sounded better than "you need a new instrument cluster circuit board from the dealership."
So I got under my dash last night with a mini maglite and poked around at all the wiring from the fuse box to the I/P.  Really knocked around the harnesses, then pulled a Fonzie on top of the dash above the gauges, knocked them around.  Problem has not shown up after repeatedly turning the truck on and off, the odometer is reading true and so are the other gauges.  So sounds like a connection somewhere.
Posted: May 31 2011 at 8:51pm | IP Logged Quote frontierguy
You may want to remove the cluster and tighten all the
screws on the printed circuit board.
mmgearhead80
U.S. - Washington
Posted: Jun 05 2011 at 9:29pm | IP Logged Quote mmgearhead80
Just did this thanks.  The screws were tiny and had lock washers but none were very tight.
mrwhizard
Official Sponsor
Official Sponsor
Posted: Jan 31 2012 at 7:00am | IP Logged Quote mrwhizard
Common problem with these instrument clusters. We repair these and many other instrument clusters at a very reasonable price. Visit Mr. Whizard Technical Services for more information.
• Do not dig up old threads. If you want to continue an old discussion (older than 1 month), create a new thread and reference the old one in your post.
Back to Top View mrwhizard's Profile Search for other posts by mrwhizard Visit mrwhizard's Homepage
