Subject Topic: Hub question for wheels, need help Post ReplyPost New Topic
HOTWHEELS
Posted: Jan 23 2011 at 4:10pm | IP Logged Quote HOTWHEELS
 Hey guys.
 I have an 02 crew cab v6. My tires are  dangerous and I need new ones. I have fallen on hard times and just need to get by for a few months.
 My truck has 6 lugs, 15 inch wheels. I was wondering how far back these trucks used 6 lugs. I think they were 5. My 02 came with a full size spare and I am running it now. I would like to find 3 more spares. The spare is actually the same long trail ta that came on the truck.
 I have a 1990 model manual that I can use for most of the mechanical stuff on the 02. Tried and true design for sure.
 My local pick a part has an 95 truck, and 3 pathfinders, 96,97,98. It seems like the pathfinder had narrowier wheels on some models.
 I know used tires are dangerous, and old ones are more dangerous. I am a honda auto tech going thru tough times. Like I said just need some time.
 Any help is appreciated. Thanks
Back to Top View HOTWHEELS's Profile Search for other posts by HOTWHEELS
davidjbrady
Posted: Jan 23 2011 at 9:42pm | IP Logged Quote davidjbrady
As far as I can recall, Nissan has used 6 lug wheels going back as far as Datsun, pre 1982.
I was under the impression they are all interchangeable,( as long as the wheel diameter is the same) I would just be sure you have the same size wheels and tires on the same axle. Do you have 4X4?
08 Frontier CC, 4X4, LWB
Posted: Jan 23 2011 at 10:08pm | IP Logged Quote lakota
The 1999 Frontier Se cast aluminum 4x4 wheels are hub-centric, 6 lugs on 5.5” dia., 15”dia. X 7” wide, 5.250 Back Spacing, centering hole is 3.925 inches in diameter. Pre-Runners wheels should be the same.
The 1998 to 2004 bolt pattern and off-set should be the same with wheel diameters 15, 16, and 17. Later models have a different bolt pattern.
The Hard Body 4x4s had much less off-set so the wheels and tires would stick out from under the fenders.
I don't know about the Two wheel drives.
Have a good one Don S..
HOTWHEELS
Posted: Jan 25 2011 at 8:27pm | IP Logged Quote HOTWHEELS
 Thanks guys. I looked in my 1990 manual and it shows 6 lugs. It is a 2wd by the way.
 The local pick a part has 3 pathfinders near the same year. I am going to see if I can find 4 wheels witth 4 safe tires.
 Bfgoodrich all terrains have 120k miles. 20k of that bald. Amazing freaking tire.
 I know a some toyotas and fords have the same lug pattern. I was wondering if I had any other options.
Posted: Jan 25 2011 at 9:51pm | IP Logged Quote lakota
Toyota's yes but I don't believe the Fords do. You might check out Isuzu Troopers.
Good luck!!.. Don S..
