Subject Topic: trans fluid change at 134k?? Post ReplyPost New Topic
bcaughhorn
U.S. - Alabama
Posted: Jan 21 2011 at 4:30pm | IP Logged Quote bcaughhorn
do i need to change the fluid now or after my wife gets back from dallas? do i need to worry about anything since i havent changed the fluid since i bought the truck? i went to get a filter and fluid before but nobody sold a filter so i figured id wait. now i know there is a screen in it instead. if i change it now will i have to worry about it on her trip next weekend?
dallas is a long way from mobile. i dont need that phone call.
04 CC frontier.v6 auto (my go-kart)
Back to Top View bcaughhorn's Profile Search for other posts by bcaughhorn
Posted: Jan 21 2011 at 7:47pm | IP Logged Quote frontierguy
If you haven't done anything in 134K, I would say it is a
little late. By changing the fluid now, you risk the chance
of disturbing the build up film in the trans. As far as the
filter goes, drop the pan, spray the filter and valve body
w/ brake cleaner. Trans flushes are recommended every 30K.
Hopefully Boomer will chime in here, he is very
knowledgeable on lubricants.
bcaughhorn
U.S. - Alabama
Posted: Jan 21 2011 at 7:55pm | IP Logged Quote bcaughhorn
i bought it with 23k. i dont know what was done before then.
i was worried if i changed it now would it cause problems. its shifting fine but i would like to change it. guess ill wait until she comes back.
Boomer
Posted: Jan 23 2011 at 10:02am | IP Logged Quote Boomer
You really have waited too long on this.  I agree with Frontier guy to some extent.  Maybe what I would do is just drain the pan, replace what drains out, drive it for 2000 miles, repaet and then again.  I think the 04 Frontiers took Matic D??? That is really the same as Dexron.  But I would go to a dealer and buy the correct fluid.
I would NOT flush the trans at this point and don't let anyone talk you into that.  After a few of the drain and fills, you might want to have the pan dropped and cleaned.  This method should provide a gentle cleaning.  I would expect the fluid you drain to be burned a dark brown. Watch the trans for signs of funny shifts, slippage or other unusual behavior.  Crud that loosens can get into the valve body and clog up some of those small orifices or clog the cooler in the radiator.
2007 Nissan Frontier SE 4X4
bcaughhorn
U.S. - Alabama
Posted: Jan 23 2011 at 12:58pm | IP Logged Quote bcaughhorn
ok. thanks for the help thats what i will do. guess that will be one day next weekend. im trying to catch up on all the maintenace before i go back out of town to work. its a little hard on a tite budget
Boomer
Posted: Jan 23 2011 at 3:14pm | IP Logged Quote Boomer
Well, the drain and fill is probably the least expensive way of doing this.  If you can get through three or four drain and fills and then a pand rop eventually, the fluid should then basically be a nice red color again.  I do a drain and fill at least once a year (10,000 miles) on my 2007 Fronty using Matic S.
Also, got to bobistheoilguy.com and go to the forums on trnasmissions.  You can also ask for advice there and read lots of stuff like your problem that has been discussed.  One of the best lubricant sites on the Web.
bcaughhorn
U.S. - Alabama
Posted: Jan 23 2011 at 6:00pm | IP Logged Quote bcaughhorn
ok. thanks. i really appreciate it. hopefully its not hurt. my wife drives it and shes not hard on it so hopefully its ok
