Subject Topic: Help AC Don’t work. Post ReplyPost New Topic
baykahz
Posted: Dec 30 2010 at 11:40pm | IP Logged Quote baykahz
I have a 01 Xterra with a V6, My heater core started leaking so I have pluged the two hoses on the engine side and now the AC dont work. Does the heater core have to be connected in order for the AC to work .Can anyone help me. Thanks, baykahz
2001 Xterra, 3.3 V-6,Auto
2004 F-150 Crew, 5.4L 3V, Auto
Back to Top View baykahz's Profile Search for other posts by baykahz
Posted: Jan 03 2011 at 6:43pm | IP Logged Quote frontierguy
NO. Does the comp engage? Does the blower fan work?
baykahz
Posted: Jan 03 2011 at 11:44pm | IP Logged Quote baykahz
The comp does not engage now. Blower fan works.  Comp was working until I disconnected the heater hoses and plugged the lines. Was going to put the lines back in to see if AC would work again but one of the plastic lines coming out of the fire wall has snapped really close to the firewall. Checked the two AC fuses both are good AC switch lights up. Thanks for the info. Any more advice?
Posted: Jan 04 2011 at 6:42pm | IP Logged Quote frontierguy
It may be a coincidence, and it is low on refrigerant. Not
a good thing breaking the plastic nipple. Unless you are
very lucky, the heater/ac unit will need to be removed for
repair.
baykahz
Posted: Jan 06 2011 at 7:33pm | IP Logged Quote baykahz
The refrigerant was low and I will fill and check for the leak sometime later. I wont fix the heater because it doesnt get that cold in Hawaii.Thanks, Frontierguy and have a Great Year! baykahz
brandonmillsap
Posted: Mar 16 2011 at 8:07pm | IP Logged Quote brandonmillsap
The heater core does not have to be connected in order for the AC to work. A damaged heater core prevents the car from providing you heat during cold weather. The problem apparently lies in the AC itself, so have it examined to determine which component causes the problem.
Back to Top View brandonmillsap's Profile Search for other posts by brandonmillsap
