Subject Topic: 2005 Frontier Heater Problem Post ReplyPost New Topic
firedog937
Posted: Dec 17 2010 at 1:17pm | IP Logged Quote firedog937
Need some Help with problem solving. My 2005 Nismo has started acting up when we turn on the heater. It is taking forever to warm up then when it does it only blows hot for about 5 minutes then gets cold again. it will keep getting warm then cold. It seems to be warm when it is on the defrost but never stays warm when it is on the upper dash mode. The blower works fine and the fan motor seems to be fine. I am currently in Greece and there is no dealer here so any help is appreciated as I have to order the parts from the states then get them put in here.
Firedog937
2005 Nissan Frontier
NISMO Package Crew Cab
Back to Top View firedog937's Profile Search for other posts by firedog937
Posted: Dec 17 2010 at 8:53pm | IP Logged Quote frontierguy
Check your coolant level, may have an air pocket in it.
FrontRuner
Posted: Dec 20 2010 at 10:47am | IP Logged Quote FrontRuner
I am another that is having this same problem.  I have found that this problem is causing another problem when fixed, DO NOT allow anyone to do a high preasure radiator cleaning as this will cause the transmission cooler located in the radiator to fail destroying your trans.  So keep us updated on your findings.
Back to Top View FrontRuner's Profile Search for other posts by FrontRuner
Posted: Dec 20 2010 at 7:06pm | IP Logged Quote frontierguy
The coolers fail all by themselves.
firedog937
Posted: Dec 20 2010 at 10:58pm | IP Logged Quote firedog937
Thanks I will be working on this over the next couple of days so I will let you know what I find.
Firedog937
