Subject Topic: 06 Frontier NISMO shut down Post ReplyPost New Topic
alex973
U.S. - New Jersey
Posted: Sep 22 2010 at 9:54pm | IP Logged Quote alex973
Hi Guys my 06 NISMO would not start back, i have new battry so that is not the problem, no radio, no lights no blinkers and no ignition, i suspect it is electrical
fuse ckd, where is the ECM i heard a lot about that, and what is it sorry for mu ignorance, frontierguy are you on tonight i could not close my window it just wont power up, so i left it on a highway gas station please help.
well i towed the NISMO to the Nissan dealer, my wallet is bleeding already
folks i need your help on what the dealer might say, so i may try to save some $$ on this repair last one was the timing belt guides 12  hr for nissan dealer
it took only 6 hr with a backyard wrench who knew how to replace thanks to you gous i went bought the kit saved $1300
regards
Alex
alex06NISMO
Back to Top View alex973's Profile Search for other posts by alex973
Posted: Sep 23 2010 at 7:26pm | IP Logged Quote frontierguy
Possible IPDM E/R. Does the engine turn over?
alex973
U.S. - New Jersey
Posted: Sep 24 2010 at 7:44am | IP Logged Quote alex973
Hi Frontierguy, noo everything shut down the main fues was fried, i went through
some rough weather there was lightning near me like 3' away hit the trailer
infront of me i tought it missed me the car shut down, it started right back
went in to fill gas shut engine off, it would not start back, tow to nissan
found the fuse blew, it is $$ always with the dealers, some are honest & some
are not, i am going to have them reset the airbag light done on a recall
as you sugested, i will let you know today when i pick up the truck
thanks
happy motoring
Alex
alex06NISMO
alex973
U.S. - New Jersey
Posted: Sep 24 2010 at 9:05pm | IP Logged Quote alex973
well it was very expensive trip to the dealer, i nblew the main fuse, that was
easy the bad part was the axle seals leaked, and destroyed the break
pads, ans shoes so i am out a $1000 out of pocket ouch:(
thanks for your help
alex06NISMO
NorthrnManitoba
Canada
Posted: Oct 19 2010 at 10:30am | IP Logged Quote NorthrnManitoba
Hey Frontier GUY
recently bought used 2007 nismo 4x4
filed up with gas realized gas gauge screwed.
most times truck starts fine, but once in a while go to start truck and it turns over but will not start almost sounds like no gas is being delivered. so i had gas gauge and fuel pump replaced at same time . now my gas gauged worked properly but still every once in awhile( which always seems to be in the most inoppurtune time) the truck will turn over but not start then leave say an hour try again still nothing then next hour i tried it would start right up. when it does start it starts good so cant be injectors or spark plugs or anyrthing like that can it? brand new fuel pump so...
starting to think it it is an electronic component or a relay with contacts that do not close proprly   ??? does this sound like a bad IPDM E/R?  any help would be greatly appreciated every time the garage puts its code reader on the truck it will start up and they do not recieve any codes and there is NO check engine light or anything like that?????? need help quick the cold weather is on its way!!!!!
Back to Top View NorthrnManitoba's Profile Search for other posts by NorthrnManitoba
Posted: Oct 19 2010 at 8:01pm | IP Logged Quote frontierguy
IPDM E/R is a possibility. Might want to have the throttle
cleaned, self learn control cleared and IAVL performed
along with checking and cleaning the engine grounds.
NorthrnManitoba
Canada
Posted: Oct 21 2010 at 6:22pm | IP Logged Quote NorthrnManitoba
YEEEEESSS finnaly got a code to show up!
thanks for the suggestions frontier guy but it wasnt that stuff code came up it read P1614 NATS         it might of said something else after but i forget
i think that is like Nissan Auto Theft System>>>?? am i right . maybe like a chip inside the key or something, maybe the chips transducer in the key or the reciever in the truck would be going?? could u give me any info u know???
NorthrnManitoba
Canada
Posted: Oct 21 2010 at 6:26pm | IP Logged Quote NorthrnManitoba
because my truck still starts most of the time its just every once in a while it doesnt start but seems to slowly and very slowly be getting worse. yeh when we got the code at my garage today( not a nissan garage i am far away from the neareast one like 6 plus hours one way) it was in the vehicles code history and like usual with the reader hooked up it started for us and then the code reader screen jumped from history to current codes and read NONE . so it must be P1614 NATS
Posted: Oct 21 2010 at 7:27pm | IP Logged Quote frontierguy
P1614 refers to the IMMU-key - How many keys do you have
and have you tried any of the other keys?? If the other
keys work OK , the key ID chip is malfunctioning in the culprit key. If all the keys act up, the dig list continues
on. Keep me posted.
NorthrnManitoba
Canada
Posted: Oct 22 2010 at 7:45am | IP Logged Quote NorthrnManitoba
i just got one key with the truck. is the chip in the actual key itself or in the FOB
Page of 2 Next >>
