Posted: Apr 09 2010 at 4:59am | IP Logged
the previous description of how my obd2 connector is wired was backwards. Sorry, I was looking at the male connector. Anyway, on the 16 pin female connector mounted under the fuse panel on the drivers side, I have a wire coming in at the 4,5,7, and 16 position; 4 and 5 are grounds and they both check out as grounded to the chassis. I have 12 volts on pin # 7 and after doing research I think this is where the actual data is transferred. The problem is there is no power on pin # 16 which is suppose to be the power source. I'll try checking fuses again but any other ideas wouls be appreciated.
Thanks
