Subject Topic: A couple of issues with my 2005 Frontier Post ReplyPost New Topic
lakersfreak
Posted: Feb 24 2010 at 10:43am | IP Logged Quote lakersfreak
Hell to all!!!! I have 2 issues. 1, my air bag light won't
stop blinking. I've tried the reset procedure (off and on 3
times, counting to 5 Mississippi, etc...) and it won't
work! After the diagnostic mode it starts flashing in a
sequence of 2 long flashes followed by 2 quick flashes. I
really don't want to take it into dealer! Please not that I
have changed the factory radio. My second problem is my
AC/Heater won't work on number 2! 1,3,4 work fine but
number 2 acts as if its off. Any ideas???? THANKS IN
ADVANCE!
Back to Top View lakersfreak's Profile Search for other posts by lakersfreak
Posted: Feb 24 2010 at 8:27pm | IP Logged Quote frontierguy
Have you had the recall done for the front impact sensor(R0807)????
Most likely need a blower resister.
< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
lakersfreak
Posted: Feb 25 2010 at 1:15am | IP Logged Quote lakersfreak
When was the recall? I don't remember it!
Jimmy54
Posted: Feb 25 2010 at 2:06pm | IP Logged Quote Jimmy54
Did the light come on right after you changed the radio? Maybe had the key
on and disconnected the air bag indicator light, if that is the case will need
to take to the dealer because that sets a hard code that can only be cleared
by scan tool.
second I would agree blower resistor
Posted: Feb 25 2010 at 4:26pm | IP Logged Quote frontierguy
Recall came out 1-24-09 call your dealer. You did mention that you did not have the radio out, correct????< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
lakersfreak
Posted: Feb 26 2010 at 8:56pm | IP Logged Quote lakersfreak
I actually do have the radio out, but its been about 4
years since I took it out.
