Posted: Feb 16 2010 at 8:06am | IP Logged
frontierguy wrote:
2001FrontierXE wrote:
I have the same problem, but only happens when the temp outside is 50 degrees Fahrenheit or below. No check engine light, and I use Fram Oil Filters to answer the question posed to surfahjammer. |
My concern is with the AIR FILTER not the oil filter. < id="gwProxy" ="">< ="jsCall();" id="jsProxy" =""> |
I must have had one to many beers when I read the original post. Copy AIR FILTER. Its an aftermarket Specter and is oil impregnated.
__________________ 2001 Nissan Frontier King Cab XE 2.4 5spd airintake/cherrybombturbo
(past Nissan/Datsuns)
1970 PL521 1600
1994 Nissan Hardbody
1995 Nissan XE
