Subject Topic: Transfer Case????? Post ReplyPost New Topic
1223cole
U.S. - Maine
Posted: Feb 02 2010 at 6:33am | IP Logged Quote 1223cole
Hello folks.  I have an 09 SE 4x4 crew cab (10,000 mi.) that has developed a humming/whistleing noise that seems to be coming from underneath the truck. This starts aorund 20 mph and is far worse when the air temp is cold. I have checked for loose heat shields etc. The local dealer has already changed the front shaft u-joints.....didn't work.....and now they swear its coming from the transfer case, but I'm not convinced. Wondered if any of you have had a similar problem and would like to hear your thoughts.
ehc
Back to Top View 1223cole's Profile Search for other posts by 1223cole
Posted: Feb 02 2010 at 7:06pm | IP Logged Quote frontierguy
Tires cupped???   Wheel bearing????< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
1223cole
U.S. - Maine
Posted: Feb 02 2010 at 7:33pm | IP Logged Quote 1223cole
The tires seem fine....rotated a few weeks ago. My experiance with wheel bearings is that they make a growling noise and you can usually hear it at all speeds or only when you make a turn.  Good thuoght tho. I'll suggest it to the mechanic.
Thanks
ehc
